hooverstupidbull Posted January 16, 2019 Share Posted January 16, 2019 Hello, Who could confirm this VOX VFS2A footswitch should work connected to the FS 4/5 input. Thanks a lot ;-) Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted January 16, 2019 Share Posted January 16, 2019 Yes it should work. If you haven't bought it yet there might be better options to consider, but if it's already in your arsenal and you're considering buying a Stomp this should do the trick. Quote Link to comment Share on other sites More sharing options...
hooverstupidbull Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks Kilrahi. i didn't buy it yet. As I use my HX stomp only with presets, I would like to add two more presets with this footswitch. Do you think it is ok? Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted January 16, 2019 Share Posted January 16, 2019 45 minutes ago, hooverstupidbull said: Thanks Kilrahi. i didn't buy it yet. As I use my HX stomp only with presets, I would like to add two more presets with this footswitch. Do you think it is ok? Yeah, it should be fine. Reviews say it's pretty sturdy, and it looks like it comes with the appropriate cable so that's not a bad deal either. Quote Link to comment Share on other sites More sharing options...
hooverstupidbull Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks a lot. It is ordered now ;-) Quote Link to comment Share on other sites More sharing options...
Mends Posted January 5, 2024 Share Posted January 5, 2024 Hi guys, it's quite old topic, but I'm hoping to get some help please... I have a VFS2 and wanted to use it as additional stomps to my HX Stomp XL. I set it up according to the manual and would say is partially working... Issue is: I have to press it twice to actually get the stomp to work. For example: I press one of the VFS2 stomps (light turns on), but nothing happens > then I press the same stomp again (light turns off) and the action realises (i.e. activate bypass) Both VFS2 stomps are behaving the same way. This footswitch is working perfectly - I tested direct into my Vox AC and works as expected. Any suggestions? Many thanks, Quote Link to comment Share on other sites More sharing options...
