Sign in to follow this
alheeren
Using guitar and mic on separate outputs
Hey, gang!
I’m just about to pull the trigger on a Helix and I as wondering if you could use a guitar and mic and separate the outputs?
On my TC Helicon Voicelive 3 Extreme I can run outputs separately with guitar out the left xlr output and vocals out the right. This is extremely useful as I can run each output direct into a PA and adjust each channel from there.
The thing I’d like is using the Helix as a simultaneous guitar/vocal processor with each having its own processing path and output.
Is this possible on the Helix?
Thanks!
Yes you can do that with Helix. In the Helix preset you would use a dual path setup. Assign one path Input to guitar and the other to Mic. For the Output assignments you have options. For instance, just before the Output block in each path you could use a mixer block to pan the signals fully L and R; this would correspond directly to your description. Or, you could choose to use both the XLR and 1/4" outputs if you want to retain a stereo output for each. Or you could use an FX Send. Or......
