blekenbleu Posted March 2, 2019 Share Posted March 2, 2019 A black import JTV-89F bought from eBay was received in seemingly good condition 2 days ago. Monkey reports flash version 2.10 (2:33 was tried and seems to behave identically). Pressing model (or tuning) knob seems to have no effect, and I have yet to notice any LED illuminating. Really, unclear what to expect; should an active model name on the knob be backlit? Yesterday, Workbench HD somehow provoked the JTV-89F into Variax mode (no LED noted), and blending worked between magnetic and model sounds from both 1/4 phone and VDI connections, but model output has not yet been achievable again today.. I try combinations of battery or VDI power and VDI connection via USB dongle or HD500, with and without 1/4 phone (which seems necessary when using battery with USB dongle). What am I missing? * Is there no explicit way to force model output using Workbench HD? * Is there a video that clearly demonstrates JTV-89F model/Variax mode switching? ---- On a semi-unrelated note, why does Workbench HD Read Me for version 2.14 continue warning to use it only with the USB dongle? I read that there were problems with older code versions, but audio gets buzz/ticks when rotating either JTV-89F volume or tone control when VDI is connected to the USB dongle, and NOT when connected to my HD500; yesterday's modeling success occurred while running Workbench HD via HD500..?? Prior to that, I also had issues getting Monkey up to version 1.78 on macOS 10.13.6; perhaps Windows users have it easier. Quote Link to comment Share on other sites More sharing options...
blekenbleu Posted March 2, 2019 Author Share Posted March 2, 2019 (edited) OK, I found an article which declares this is/was a fairly common problem: Fixing a faulty Variax model selector Removing the model knob and pressing its shaft woke modeling and the LED, >>after releasing<<. A dab of hot glue stuffed into that knob cavity qualifies as a cure. Removing the knob for tuning, with seemingly the same LED lashup, and pressing its shaft did nothing obvious, but >>turning it<< illuminates that LED, but >>only briefly<<; too bad this is both unintuitive and undocumented.. Edited March 2, 2019 by blekenbleu healed myself after more research Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 2, 2019 Share Posted March 2, 2019 Workbench can work thru an HD500, but an HD500 won't do Flash updates, you need the interface device a RJ45 cable accessories. Quote Link to comment Share on other sites More sharing options...
blekenbleu Posted March 2, 2019 Author Share Posted March 2, 2019 Oops, I used the HD500 with Monkey to revert Variax from 2.33 back to 2.10 .. seems OK. Thanks for the warning; can that interface device also work with a Variax 300? I lack an original USB interface for that older Variax. FWIW, a JTF-89 model can be tweaked to make single string tones indistinguishable from magnetic, at least to me.. Dialing up alternate tunings is a blast! Quote Link to comment Share on other sites More sharing options...
