scuzzphut Posted May 4, 2019 Share Posted May 4, 2019 Hi, I'm using my HX Stomp as an audio interface - USB to PC - Line Outs to powered speakers. When I want to use headphones, I have to unplug the powered monitors from the Line Outs at the moment. Is there a setting anywhere that would automatically mute the Line Outs when headphones are plugged in ? Can I adjust the volume of the headphone out and Line outs separately ??? Thanks ! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 5, 2019 Share Posted May 5, 2019 2 hours ago, scuzzphut said: Can I adjust the volume of the headphone out and Line outs separately ??? Doesn't look that way from the manual. If it's really important to you, you could get a small mixer like this: https://smile.amazon.com/Alto-Professional-ZMX52-5-Channel-Channel/dp/B004TM31QK/ref=sr_1_3?keywords=mixer&qid=1557020754&s=musical-instruments&sr=1-3 About $50. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 5, 2019 Share Posted May 5, 2019 On 5/4/2019 at 7:06 PM, scuzzphut said: Hi, I'm using my HX Stomp as an audio interface - USB to PC - Line Outs to powered speakers. When I want to use headphones, I have to unplug the powered monitors from the Line Outs at the moment. Is there a setting anywhere that would automatically mute the Line Outs when headphones are plugged in ? Can I adjust the volume of the headphone out and Line outs separately ??? Thanks ! The Global --> 'Ins/Outs' --> 'Volume Controls' parameter will select which outputs you want the Volume knob to control. It can control the 1/4 output and headphones("Main+HP") or only the headphones("Phones"). Unfortunately the 1/4 outputs remain at unity gain when this parameter is set to 'Phones'. I can definitely see where adding a headphones parameter option that muted the 1/4 outputs might be helpful in certain setups. Line6 may have figured that if you are going to use your headphones you won't have an amp on. Don't know how it would impact the headphone sound but another simple solution would be an in-line volume control for your headphones like the ones below from Amazon. Unlike the mixer solution rd2k recommended you might have to disconnect or turn down/off your monitors/'guitar amp' depending on your rig setup. The 1/4 model is made by Koss and they make decent headphones so their volume control might be worth a look. Both models are less than $10. https://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH?ref_=fsclp_pl_dp_1 https://www.amazon.com/Stellar-Labs-1013015470-Control-Headphones/dp/B008DJTB32 Quote Link to comment Share on other sites More sharing options...
scuzzphut Posted May 5, 2019 Author Share Posted May 5, 2019 Thanks for your help guys. Much appreciated. Quote Link to comment Share on other sites More sharing options...
mmtmusic Posted April 23, 2024 Share Posted April 23, 2024 Resurrecting this as I'm in this similar scenario. Helix' outs going to the main desk/everyone's IEMs etc. Would love the Helix muted whilst I use headphones to continue editing sounds and not FOH constantly having to mute/unmute the Helix their end. Is this still not a possibility? Quote Link to comment Share on other sites More sharing options...
