C4TH Posted May 10, 2019 Share Posted May 10, 2019 Hi people, I'm having a problem with using my expression/wah (Line 6 EX1 pedal > expression input 2). I have a particularly song with 3 snapshots set up, with the wah assigned to all 3. The problem comes, when if I use the wah during a part on snapshot 1, then return the wah to heel position (off), I then switch to snapshot 2 and then use the wah again, but the wah then turns on in the heel position, then turns off when I rock the wah forward. Just wondered if anyones experienced anything similar, or knows a way round this. Thanks. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 10, 2019 Share Posted May 10, 2019 Snapshot 2 was saved with the wah engaged, that's all. Select snapshot 2, and with the pedal heel down, navigate to the wah block and hit "bypass" so it's off, then save. Quote Link to comment Share on other sites More sharing options...
C4TH Posted May 10, 2019 Author Share Posted May 10, 2019 Thanks for the reply. Do you know if it essential that you turn the wah off before you switch snapshots? I was just trying what you said, which seems to work. But if I switch snapshots with the wah on, it seems to do what I said previously. Quote Link to comment Share on other sites More sharing options...
