ulimusik Posted May 15, 2019 Share Posted May 15, 2019 Have the HX Stomp since a couple of days. For me as Bass-Player, but not in the metal-genre, i use Effects not often but as a spice with a small but great pedalboard. The Hx-Stomp delivers great sounds, very usable. Found nearly every Pedal i use i can find an equivalent that is usable: Tuner ist ok, great distortion sounds, Delay / Reverb is good, can find a nice Phaser and Compressor. I like the Mu-Tron filter simulation, i have the original reissue and it´s great. The first i´m missing is one of the Studio standards. While a LA2 is on board, a 1176 istn´t! I iconic Comp. Really? Or did i overlooked it? BUT: For most Bass Players outside the Overdrive and Fuzz Bass players, the most used and sought after pedals where octavers. I own most of them. And my favorites are the most iconic among bassists: the Boss OC-2 and a Mu-Tron Octavider. While the second one isn´t as present as the first (because it was very expensive i think) it has a unbeleavable sound with suboctave only and green ringer on. The Boss OC-2 is outstanding with only one octave down or Original + one octave down. But - the HX Stomp is anounced also as Bass Pedal - and non of the iconic Octavers are included (could name a couple of other brands). And for me: HX-Stomp would be great, but had to add two octavers. Don´t know if i will hold it. Or is there a possiblility to make a patch that fits my need? If yes it would be the greates unit i tested. Can you help me of have any suggestion? Thanks. Quote Link to comment Share on other sites More sharing options...
rvroberts Posted May 15, 2019 Share Posted May 15, 2019 Have you experimented with the pitch/synth modules like Simple Pitch? And adding either AM Ring (if you want a tad of ring modulation) or some Mutant Filter on low mode? Not a bass player, but I can get a lot of classic octave sounds right there. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 15, 2019 Share Posted May 15, 2019 There is a Bass Octaver effect under the Pitch/Synth>Legacy menu. It’s based on the EBS Octabass effect. Quote Link to comment Share on other sites More sharing options...
njglover Posted May 15, 2019 Share Posted May 15, 2019 One of the legacy synths (not explicitly an octaver) can be configured as a killer sub octave generator, too. Can't remember which one it is off the top of my head, but boy does it make a room rumble. Quote Link to comment Share on other sites More sharing options...
peaceland Posted January 26, 2021 Share Posted January 26, 2021 Bronze Master - now you see it, now you don't. Ouch. Indeed, sorely missing throughout the Helix family. Of course, it was present for MANY years in various Line6 incarnations - but never in the Helix. Have called this in many times. Someday, our dreams will come true... keep the faith. Peace Quote Link to comment Share on other sites More sharing options...
