Problem With My Pod Xt Live Footswitches...
Hi!
I recently bought a POD XT Live second hand. Now my issue, manually I can select all the sounds with the knob "select", but I can´t choose the sounds with my feet. For instance, the knob stomp and amp isn´t lit. Nothing happens when I hit them! Do I need to repair it in some way or Is there any software bypass. Any ideas?
Thanks in advance...
P.S The firmware and Flash Memory is up to date, I´ve checked that with the Line 6 Monkey Software
/Masse1969
One thing I would try is to see if you can turn the different effects on and off using Gearbox.  If so, that would point to maybe a pedal issue.  If you can't turn them on and off in Gearbox, then maybe its a firmware, or pod hardware issue.
Is it all the pedals that aren't working or just the effects pedals?
Interesting idea, because when I try to change a tone or effect in Gearbox I can change tone but when I come to a effect like stomp nothing happens in my XPod Live. :huh: Should I try to reinstall the USB firmware?
No pedals are lit and obvious not working, but I still can change volume on the wah/volume pedal.
Best regards from Magnus
  • 2 years later...
