reggiedadog 3 Posted May 30, 2019 Hi, Ive recently moved to Helix and Powercab+ and loving it, great range of tones for home, rehearsals and gigs. Ive also just bought a stomp for a backup/smaller stage setup. I am subsequently having a clearout of non essential gear that it is replacing. As well as bands I also play solo with an acoustic, using a TC Helicon Play Acoustic for the vocal effects and going straight into a Bose- no problems there. BUT at some smaller gigs (we have Micro pubs here in the UK- enough space for about 15 people) I have used an AER Compact 60 and run that from the Play Acoustic. The truth is though I can better and more versatile acoustic tones via the Helix/Stomp, but wondered if I could run the mic out from the Play Acoustic directly into the Powercab and use that instead? Has anyone tried this? Thanks Quote Share this post Link to post Share on other sites
SteveFrance 26 Posted May 30, 2019 Your mic has to be amplified, you won't be able to go direct into the PC+, nevertheless, you can take your Helix and create a voice second path. It means, you won't do that with the stomp too..... Quote Share this post Link to post Share on other sites
