Hx Stomp, In Ears Monitoring (IEM Routing)
thebluesman666
Howdy,
If you wish to use the HX Stomp as an IEM units to play live or rehearse with In Ears headphone,.
Here's how to achieve this.
Use an Send block (mono) at the end of your chain. Use the Send output to set to FOH or DAW to record
You don't have to plug anything in the Main OUTS. Main outs will include the playback coming from the console or mixer.
Use the Aux IN inputs on the side of the unit from the mixer to the HX Stomp. Set Return to AUX IN in Global settings. (Stereo IEM mix, use the volume control on the Stomp)
You'll need 4 cables to make it work.
1 Guitar Input
2 Send Output (Guitar signal/Pedalboard Output)
3 AUX IN L (IEM MIX)
4 AUX IN R (IEM MIX)
Cheers
hi,
Im doing this for 'silent stage' setups too. Im hoping L6 will update with a Headphone only option while using the AUXin, so we can use the mainout and save a block.
I (and a few others) have posted this idea on the L6 Ideascale website:
https://line6.ideascale.com/a/dtd/STOMP-AUXin-setting-to-Headphones-ONLY-not-feeding-MainL-R/951072-23508#idea-tab-details
Please up vote, thanks!
