fenderbenderlax Posted June 21, 2019 Share Posted June 21, 2019 Hello folks, i was wondering if it is possible to assign a single expression pedal to control the volume of two separate signals in helix. For instance what I would like to do is assign say expression pedal in the heel position to a synth sound (using midi) and in the toe position to exclusive guitar sound and then a mix in between. currently I managed to get this to work using two expression pedals each assigned independently. Thanks for your help!!! Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 21, 2019 Share Posted June 21, 2019 Yep... So you have your volume pedal set up for your guitar sound, and that's fine. Just go into the Command Center and navigate to the expression pedal you're using to control that volume pedal and assign a MIDI CC command to the expression pedal. Select whatever CC# the synth uses, and then you can set the min and max values. Since you want the pedal to act in reverse for the synth, just set the min to be 127 and the max to 0 (assuming you want the pedal to sweep the entire range of whatever CC the synth uses for volume). Quote Link to comment Share on other sites More sharing options...
fenderbenderlax Posted June 21, 2019 Author Share Posted June 21, 2019 Thanks Phil..thats worked!! Quote Link to comment Share on other sites More sharing options...
