Jepsen2000 Posted June 21, 2019 Share Posted June 21, 2019 I have a Spider V 30 amp, and now I have bought an FBV 3 foot controller, too. I notice that the FUNCTION button on the FBV 3 does absolutely nothing, and I wonder whether it should. I realize that it is intended to control the looper, which isn't there on the V 30 and the V 20 amps. Am I right that it should not do anything with my setup?!? A related question: I would love to have a looper added to my setup. Are there any recommendations out there? Thanks, Peter (from Denmark) Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 24, 2019 Share Posted June 24, 2019 Whatever looper you decide on, make sure you get a '2 button' one. The single-button loopers require a bit of a 'dance' shutting off the recording/starting playback, much easier to use a 2-button one. The problem with using a looper with a Spider amp is there is no effects loop to insert it, so you can't set up a rhythm loop with one sound, then change the sound to play a lead over it (unless you use external stompboxes before the looper). 1 Quote Link to comment Share on other sites More sharing options...
