ancal_ Posted June 30, 2019 Share Posted June 30, 2019 (edited) Hi guys, newbie here. This morning I went to set it up and I only get sound while the pedal is in bypass mode. If I engage an effect then I get silence. Has anyone else had this issue? How solve this problem? Help 58356942212__BF6A224D-D56D-449C-8961-59B39F83BFE5.MOV Edited June 30, 2019 by ancal_ More info Quote Link to comment Share on other sites More sharing options...
jheybard Posted December 29, 2020 Share Posted December 29, 2020 Hi, I am experiencing the same issue with the M5 unit. Volume significantly drops (very low output) when pedal is on. I have not found a forum that provided a solution to this issue, and I'm hoping that you can share what you did in case you got yours resolved. Many thanks! Quote Link to comment Share on other sites More sharing options...
pdk972 Posted January 23, 2024 Share Posted January 23, 2024 I've got the same issue with an M5. Worked fine. Left it on for several days. Got the blue screen. Reseated the ribbon cable, which fixed the blue scree issue, but now I have super low volume when the pedal is engaged or in DPS bypass mode. Regular volume in true bypass. Quote Link to comment Share on other sites More sharing options...
olequijote Posted January 28, 2024 Share Posted January 28, 2024 I have the same issue. Quote Link to comment Share on other sites More sharing options...
neilemborgo Posted June 8 Share Posted June 8 i had the same issue, no output on DSP bypass. low volumes bleed on drive effects. good output on true bypass, no sound when effect is on. ended up replacing the U11 IC in the board. its a 2374A PWM DC/DC Converter. it fixed it for me. Quote Link to comment Share on other sites More sharing options...
