My Line 6 M5 no sound when engaged
ancal_
  • 1 year later...
Hi, I am experiencing the same issue with the M5 unit.  Volume significantly drops (very low output) when pedal is on.  I have not found a forum that provided a solution to this issue, and I'm hoping that you can share what you did in case you got yours resolved.  Many thanks!
  • 3 years later...
I've got the same issue with an M5.  Worked fine. Left it on for several days. Got the blue screen. Reseated the ribbon cable, which fixed the blue scree issue, but now I have super low volume when the pedal is engaged or in DPS bypass mode. Regular volume in true bypass.
