zunuproject Posted November 1, 2016 Share Posted November 1, 2016 I've tried all of the suggestions from this forum, but it doesn't work on my hd500. LCD still shows Update Flash. It's very horrible. Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 1, 2016 Share Posted November 1, 2016 Sorry to say, but If you have tried them "all" then the last one is to send in a Support Ticket. Link is below titled "Support". Quote Link to comment Share on other sites More sharing options...
wilsonmartins Posted August 3, 2017 Share Posted August 3, 2017 Resolved pod hd500 continuous update flash. Connect hd500 with cable connected to the guitar input holding down move key! If you turn it on normally! Holding the left arrow to disconnect the power cord and plug it in again, leaving your hd500 to factory version. Ready problem solved! Resolved pod hd 500 continuous flash uptade Connect hd500 with cable connected to the guitar input holding down move key! If you turn it on normally! Holding the left arrow to disconnect the power cord and plug it in again, leaving your hd500 to factory version. Ready problem solved! 4 Quote Link to comment Share on other sites More sharing options...
jimbur Posted December 28, 2017 Share Posted December 28, 2017 Resolved pod hd500 continuous update flash. Connect hd500 with cable connected to the guitar input holding down move key! If you turn it on normally! Holding the left arrow to disconnect the power cord and plug it in again, leaving your hd500 to factory version. Ready problem solved! Resolved pod hd 500 continuous flash uptade Connect hd500 with cable connected to the guitar input holding down move key! If you turn it on normally! Holding the left arrow to disconnect the power cord and plug it in again, leaving your hd500 to factory version. Ready problem solved! Thanks Wilson. Problem Solved.. Quote Link to comment Share on other sites More sharing options...
cheatinelvis Posted January 22, 2018 Share Posted January 22, 2018 Resolved pod hd500 continuous update flash. Connect hd500 with cable connected to the guitar input holding down move key! If you turn it on normally! Holding the left arrow to disconnect the power cord and plug it in again, leaving your hd500 to factory version. Ready problem solved! Resolved pod hd 500 continuous flash uptade Connect hd500 with cable connected to the guitar input holding down move key! If you turn it on normally! Holding the left arrow to disconnect the power cord and plug it in again, leaving your hd500 to factory version. Ready problem solved! When I hold down the move key i also have to hold the arrow down cursor. The board boots up and I can play with it but it still won't allow me to do the reset using the left arrow key. It keeps coming up with the same "update flash" message. I really appreciate you sharing. I wasn't able to do anything past just powering it up and now i can at least play. I will check with Line 6 tomorrow. Thanks again!! Quote Link to comment Share on other sites More sharing options...
jhoven24 Posted February 13, 2019 Share Posted February 13, 2019 I have the same problem, and I tried everything that everyone say here but nothing is useful. The "Update Flash" still in the screen and the footswitches dont work. Quote Link to comment Share on other sites More sharing options...
stoptherock1 Posted March 12, 2019 Share Posted March 12, 2019 Hey, guys! I had the very same problems yesterday with my POD HD 500. I managed to solve it. Hopefully, it will help you, as well. WHAT HAPPENED: I bought a second-hand POD HD 500 unit which was perfectly working but had a bunch of user's presets which I wanted to remove all at once. The unit had firmware v2.62 installed. So to remove all presets I pressed "Reinstall latest" firmware in Line 6 Monkey and selected not to preserve my current presets there. The latest software currently is v 2.62, so it is the same version that was installed on the unit. ISSUE: The software re-installation failed with the error: "(code 80007211) Firmware update timed out waiting for a response from the device.". Then after several attempts to re-install the firmware, I ended up in the situation when the unit and was constantly displaying "UPDATE FLASH". I tried 2 different laptops (MacOS and Windows 10) and different versions of firmware. Then I downgraded to v 2.32 first (which worked) and the tried to install v 2.62 again. This last attempt to re-install the firmware made it even worse. The unit was working, but when I tried to change preset from "Son of Plexi", the unit froze and was not responding to anything. Another problem was that Monkey showed firmware version as "Unknown". The POD HD 500 Edit was saying that it needs a unit with software 1.30 or above to work and refused to work with the POD. I also tried to boot the device with pressed left nav button. Did not help. The device was, basically, unusable. MY SOLUTION: I called Line 6 support. After some time of analysis the guy from the support suggested the following: 1) Press down nav button, 2) Unplug the power cable from the POD, 3) Plug in the power cable while holding the down nav button, Now the unit was displaying UPDATE FLASH again 4) Connect unit via USB to the laptop, 5) Close Monkey (if opened) and open it again, Monkey now identified the firmware version as v2.62 again 6) Reinstall the latest firmware. This procedure did not work for the first time and failed after about 15% was completed. However, the guy suggested to try once again and see if it will move further. He also said that if it will not work, but the progress will go further, we need to try again and again. Presumably, the current firmware on the unit is corrupted. However, after the second attempt, the firmware was finally re-installed and after that, the unit came back to the normal working state. AFTERMATH: 1) The support guy was pretty surprised with the issue and said that it is super strange behavior. Even though, many people have very similar problems with this unit. Previously I had an HD 300 unit for about 6 years and never had this kind of problem with it. Same with my Variax guitar. Seems like there is some serious problem with HD 500 because I was able to find many people on forums having the same (or similar) problem with no clue how to fix it. 2) The guy from the support was super helpful and really tried to fix the problem. Big appreciation to him for this attitude. 3) If you have this kind of problems and run out of clues - call the support phone line. As you can see, they can help you with your problem via phone. However, waiting time in my case was about 25 minutes. P.S. I just noticed that 'wilsonmartins' also suggested solving the problem by pressing down the nav button. So, one more confirmation for this solution :) Quote Link to comment Share on other sites More sharing options...
chris-x11 Posted July 17, 2020 Share Posted July 17, 2020 A little late on this but PAY ATTENTION.. I had the exact same thing thing with the constant "update flash" message. The power on and holding ANY of the arrows did NOT work for me, neither different usb or pc. I am not 100% which one of the following steps worked but something worked. my fixing story includes: Have the guitar jack plugged in the pod Power on the pod holding down the "MOVE" button. It should take you to the regular kinda screen try to create and save a random sound..nothing special just put a random amp and save. after that try unplugging and plugging the power holding the left arrow of the 4 way nav pad. that should global reset. then try the same unplug and plug thing holding the right arrow of the 4 way nav pad and try the pedal calibration (https://www.sweetwater.com/sweetcare/articles/line-6-pod-hd500x-tips-pedal-calibration/) now the most important step.. Once again turn the pod on holding the move button in order to be taken into the regular pod screen. use A DIFFERENT USB to MIDI cable and connect the pod to your pc. open monkey app and try to reinstall the update locally or normally, it didn't matter for me. after the update finishes, follow the normal process of unplugging waiting almost 5 seconds and plug the pod into power again.. that worked for me. I came to the conclusion that it was a matter of CORRUPTED or NOT completely compatible usb to midi cable. Try to update the pod with another cable and if you can not get the pod to open pass the ""update flash"" screen, then try the trick of power on the pod by holding down the NAV button AND having the guitar jack plugged in the pod. hope that works for you too.. Quote Link to comment Share on other sites More sharing options...
rabeson Posted March 7, 2021 Share Posted March 7, 2021 thanks a lot :-) Quote Link to comment Share on other sites More sharing options...
