Metal-Cellista Posted July 22, 2019 Share Posted July 22, 2019 I just updated my Helix! Yeiiiii! the new EQ's work great for me and I certainly will use this tools alot. allso the new models will be explored soon. I am a little sad, that signal metering still has not made it into the update...maybe next time;) But I wondered abbout one feature which was announced on winter NAMM: Does somone know how to set this up? i found no tutorial or new manual in the www and i found nothing in the helix menus...maybe I have overlocked something but i would really like to use this feature. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 22, 2019 Share Posted July 22, 2019 When you updated, did you do the 7+8 reset? That loads the new presets, and there should be templates in the Templates Setlist. Quote Link to comment Share on other sites More sharing options...
bengtalexsander Posted July 23, 2019 Share Posted July 23, 2019 in the command center you can assign every switch to send a keystroke with or without modifiers (ctrl, shift, etc). so you are limited to 10 keys or whatever. it's not "turn it into a keyboard", it's make a switch send a certain keystroke. Quote Link to comment Share on other sites More sharing options...
Metal-Cellista Posted July 24, 2019 Author Share Posted July 24, 2019 On 7/23/2019 at 3:00 AM, bengtalexsander said: in the command center you can assign every switch to send a keystroke with or without modifiers (ctrl, shift, etc). so you are limited to 10 keys or whatever. it's not "turn it into a keyboard", it's make a switch send a certain keystroke. Thanks. That's exactly the input I needed. I don't work with MIDI so I my mind completely ignored the command center because of a "general lag of relevance" haha:) Quote Link to comment Share on other sites More sharing options...
