keykeeper Posted January 8, 2014 Share Posted January 8, 2014 If I connect the POD HD with a USB cable is it then possible to record both a mic input and guitar at the same time? If yes how do I set up the preset to enable this?? Quote Link to comment Share on other sites More sharing options...
MartinDorr Posted January 8, 2014 Share Posted January 8, 2014 I have not done this, but the setup would be as if you have 2 totally separate signal paths through the Pod, i.e., guitar on input 1, mic on input 2, different effects/amps on path A for guitar and whatever you want to do with the Mic on path B, mixer panned hard left and right, etc. so that each one of the 2 stereo sub-channels has only the signal and processing of the guitar and the Mic. On USB you'd see the same: the guitar on 1 side and the Mic recording on the other. Your DAW will probably allow to treat each one as a single Mono input for recording on 2 mono tracks. I would not jump on my info and wait a little. There are probably later responses coming from people who have actually done this or something similar. Martin Quote Link to comment Share on other sites More sharing options...
FrozenOzone Posted January 8, 2014 Share Posted January 8, 2014 Yes this can be done. Most of my patches are setup to use input path 1 as guitar and input path 2 as a Microphone. I use my POD500 as a vocal processor with guitar. MartinDorr summed it up pretty well but here is a screen shot of my setup: Also, I do not use an amp on the vocal side even though there is an amp there in the picture. Quote Link to comment Share on other sites More sharing options...
keykeeper Posted January 8, 2014 Author Share Posted January 8, 2014 Ok great! Thank you both for the replies:) Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 9, 2014 Share Posted January 9, 2014 Here is a preset I put together some time ago to do what you want. Just customize to suit for electric guitar. http://line6.com/customtone/tone/215659 Quote Link to comment Share on other sites More sharing options...
