Sign in to follow this
logicbdj
G10 wireless does not like piezo?
Hi... Even with the G10T pushed all the way into my Parker Dragonfly guitar, I get no signal from my piezo bridge pickups.  Is this typical?  No problem in using a cable, but I often blend my pickups and prefer the G10 system due to its clarity.  Any advice?
Does your Parker have a TRS output jack? If so, then I imagine the piezo signal would come through on the ring connection. The G10T won't work with that, as it uses the ring for charging. You could try using the little TRS to TS adapter that came in the box. That would short the ring connection to the sleeve, so that may work.
Thanks for the suggestion... that does work.  The only issue is a high-pitched hum that I can't eliminate.
On a related note, I have a transformer from Radio Shack (The Source) that's about 3-4 inches long... you plug a 1/4 inch and it's end is 1/4-inch.  When I use that in the guitar (along with the G10T) it works fine without any high-pitched hum.  And so, although a bit of a long thing sticking out, it works.
Yes, the guitar does have a TRS... it includes a cable that allows you to split the signal to two different amps.
OK, that didn't work... sucked the life out of my tone.  The transmitter also doesn't work with one of my Ibanez guitars... the input is too deep for the G10T to fit (even with the adapter).
