Sign in to follow this
nickpirtle
HX Stomp configuration with pedalboard
I recently ordered the HX Stomp and REALLY hope I can use it the way I'm hoping to. So please someone tell me if this is possible.
The HX Stomp is going to replace my DD500 - so in my case drives are before and mod/reverb is after.
In a live situation I want to run my amp as usual, and then an amp model from the HX to run stereo. Is there a trick to configure it this way? I read where I can create a second "path" and the output would be the FX out I think, but I still would like to have my mod/reverbs (which are after the HX) on my board going to both amp and hx amp signal.
So basically I want the same signal going to both my amp and direct, while using the the effects on the HX for mostly delays.
Could you provide a few more details?  What other pedals are you hoping to combine with the Stomp?
Including those pedals, what is the actual exact signal chain you're wanting? (Example: Boss DS1 >>> HX Stomp >>> Amp >>> Strymon Timeline)
My chain is:
Buffer- comp - King of Tone - Semaphore Trem - M5 - El Cap - HX Stomp - Wet reverb - AMP
I want to run it just like that to my amp, but have an amp model going out to FOH to run stereo. I just don't want to lose the Wet reverb in that chain.
Thanks Kilrahi
If you have the stereo Wet reverb it will work.  But if you have the mono version it will not.
You have to split the signal after the delay or you can have two delays.  Then you have to split the output and pan one left and one right.  Easier to do with Edit than on  the Stomp but still achievable.
