Jakatone Posted August 16, 2019 Share Posted August 16, 2019 Hi guys, so I have a basic setup on the Helix, a few od's, phaser and delay/reverb. But the XLR out is completely dry, no effects at all, only the DI sound. The output is set to Multi. Any thoughts? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 16, 2019 Share Posted August 16, 2019 Is this happening with all presets? Try building a new preset from scratch, one block at a time, to replicate (including all block parameter settings) a preset that is problematic. After adding each block test the XLR output to try to identify the block/structure that is causing the problem. Ther may be a split/merge block that is routing the signal in an unexpected manner. Quote Link to comment Share on other sites More sharing options...
Jakatone Posted August 16, 2019 Author Share Posted August 16, 2019 Thanks for that question, I forgot to mention that it works fine with other presets. I'll explain more in detail: The preset has no amp/cab blocks, I run a 1/4 out to the amp, and the plan is to run a FX only XLR to the recording desk for the ability to add a second amp later which will compliment the live one. It goes exactly like this: Comp/Phaser/OD/Fuzz/FXLoop1/Delay/Reverb. Now that I think about it, I'm guessing the Loop has something to do with it. Quote Link to comment Share on other sites More sharing options...
Peter Posted August 18, 2019 Share Posted August 18, 2019 But if you set the output to multi, 1/4-Out and XLR-Out should sound the same. I don't think the loop has something to do with it (test it by deaktivating the loop). Because it works on the other presets, I would guess the preset is faulty. ...Maybe you have a clean Path2 in the preset and the XLR-Output is accidentally activated? Quote Link to comment Share on other sites More sharing options...
