Moon_Raven Posted August 16, 2019 Share Posted August 16, 2019 I have updated Helix Floor from 2.71 to 2.81, and the large volume knob does not work anymore. It is just 'stuck' at quite a high volume and turning it does nothing. What can I do to fix this? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2019 Share Posted August 16, 2019 Did you restore from backup after doing the update? If not your Global Settings would have been lost. Go to Global Settings>Ins/Outs>Volume Knob Controls and see what that's set to. It sounds like it's not set to control whatever outputs you're using. Quote Link to comment Share on other sites More sharing options...
Moon_Raven Posted August 16, 2019 Author Share Posted August 16, 2019 I cannot do that - when I enter the second page of global settings, the Helix freezes completely and needs to be restarted. How can I fix THAT? Is there any way I cna just go back to the update that was working? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2019 Share Posted August 16, 2019 Did you do a FS7 & FS8 reset after updating? It sounds like you probably should. Quote Link to comment Share on other sites More sharing options...
Moon_Raven Posted August 16, 2019 Author Share Posted August 16, 2019 I did not, since I figured I don't need the 2.80 factory presets/templates, so I skipped the step 4 from the update instructions. I proceeded to restore the presets from my 2.71 backup. Is it safe to try the FS6 & FS8 reset now? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2019 Share Posted August 16, 2019 2 minutes ago, Moon_Raven said: I did not, since I figured I don't need the 2.80 factory presets/templates, so I skipped the step 4 from the update instructions. I proceeded to restore the presets from my 2.71 backup. Is it safe to try the FS6 & FS8 reset now? It's FS7 & FS8, but yes, it's safe, and that's what I'd recommend doing. Just restore from backup again after doing the reset. Quote Link to comment Share on other sites More sharing options...
Moon_Raven Posted August 16, 2019 Author Share Posted August 16, 2019 I did the FS7 & FS8 reset (without restoring my backup presets yet) and the volume knob is still not working, and the global settings are still freezing the whole unit. Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2019 Share Posted August 16, 2019 5 minutes ago, Moon_Raven said: I did the FS7 & FS8 reset (without restoring my backup presets yet) and the volume knob is still not working, and the global settings are still freezing the whole unit. Well, I guess I'd try reflashing the firmware then. If you're still having issues, I'd suggest opening a support ticket. Quote Link to comment Share on other sites More sharing options...
Moon_Raven Posted August 16, 2019 Author Share Posted August 16, 2019 I will try it now. If it does not work, can I downgrade to a previous version that worked for me? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2019 Share Posted August 16, 2019 Just now, Moon_Raven said: I will try it now. If it does not work, can I downgrade to a previous version that worked for me? Yes, you can rollback... It would still useful to CS if you opened a ticket to report what you're experiencing, though. I don't recall seeing other reports similar to what you're experiencing. Quote Link to comment Share on other sites More sharing options...
Moon_Raven Posted August 16, 2019 Author Share Posted August 16, 2019 I went back to 2.71 and everything seems to work fine. I have one question though - do I also need to downgrade my HX Edit, or can I use HX Edit 2.81 with Helix Floor 2.71? Quote Link to comment Share on other sites More sharing options...
Frosenborg Posted August 17, 2019 Share Posted August 17, 2019 20 hours ago, Moon_Raven said: I have updated Helix Floor from 2.71 to 2.81, and the large volume knob does not work anymore. It is just 'stuck' at quite a high volume and turning it does nothing. What can I do to fix this? Are you using headphones? I mostly play by using headphones connected to the Helix and noticed that the volume knob doesn't affect output volume after updating to 2.81, as it did in 2.71 The volume knob does work ok if I connect the Helix to an amp. Quote Link to comment Share on other sites More sharing options...
