Save Function Via HX edit "misbehaving"
Heavyville
maybe there is already something addressing this already.  purely a lazy question right now.
anyone notice saving snapshots via HX edit does weird things to all the other snapshots.    For instance saving a snapshot with Delay and reverb turned on the day and rev for all snapshots.  Could;t get around it...   However double saving every snapshot from the actual unit seemed to work.
I can live with it, but i'm sure we can figure it out team !!!!!
GO!   i'm hoping its a DFU error, those are easy to fix.
That's just how they work... in any new patch, when you set up your first snapshot, the remaining 7 snapshots will be identical by default, until you go into each one individually and make one or more changes.
"If you select a snapshot that hasn’t yet been altered, it appears the same as the snapshot you came from. As soon as you alter a new snapshot (say, by enabling or bypassing an amp or effect block), the snapshot becomes "active" and remembers any changes."
https://helixhelp.com/manuals/helix/snapshots.html#snapshots-block-bypass
I get that part, that isn't new.
I discovered while buiding a new patch with snapshots that after everything was saved and I got my snapshots in order. I was fine tuning them and turned on/off a few blocks. While hitting the save button on HX edit i noticed that it saved all the blocks the same for all snapshots.   So if i had a boost on for a lead, all the snapshots now had the boost engaged which is not a normal behaviour.
using the save button on the physical unit solved the issue and the snapshots saved correctly.
