andgo Posted September 4, 2019 Share Posted September 4, 2019 Spider v20. Preset knob problem. Lost settings. Clean-Chime-Crunch-Chunk ..... not match Spider V Remote. FX2 and FX3, press the Save button - no result. HELP me!! Quote Link to comment Share on other sites More sharing options...
ADBrown Posted September 6, 2019 Share Posted September 6, 2019 It looks like the preset names correctly match up with Spider V. I'm not fully clear on your issue, it seems you are having trouble saving? Quote Link to comment Share on other sites More sharing options...
andgo Posted September 7, 2019 Author Share Posted September 7, 2019 After you install 1.00.3, When I twist the knob "Preset" on the display PC "spider v remote" you see the values are preset names Non-correctly. What to do? Quote Link to comment Share on other sites More sharing options...
andgo Posted September 9, 2019 Author Share Posted September 9, 2019 I wish to clarify my problem I have the problem with knob “preset”. There are 16 mods ( BASS, ACOUSTIC,CLEAN1/2, CHIME1/2, CRUNCH1/2, CHUNK1/2, INSANE1/2, VIBE1/2, AMBIENT1/2), but in fact I have only four( it doesn’t match the settings which I had after buying it). If I connect my spider 6 to my PC to set it, everything is correct. What should I do to fix it? I see this values on my switch “spider v20” on the “spider v remote”: BASS=bass ACOUSTIC=acoustic CLEAN=chime2:echoes CLEAN2=chime1:class-A CHIME=chime1:class-A CHIME2=chime2:echoes CRUNCH=chime2:echoes CRUNCH2=chime1:class-A CHUNK=insane2:lunatic CHUNK2=insane1:criminal INSANE=insane1:criminal INSANE2=insane2:lunatic VIBE=insane2:lunatic VIBE2=insane1:criminal AMBIENT=ambient1:black hole AMBIENT2=ambient2:glass When I click “f2+f3+save” it doesn’t return to factory settings. ( When I need to click “f2+f3+save”? Do I need to press “f2+f3+save” when “spider 5” is turned on or "Power+F2+F3 and Save”?) Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted September 9, 2019 Share Posted September 9, 2019 I get what you're saying. The presets that are saved to the amp don't match the knob for the amp. So if you select "clean" on the amp it does NOT choose the clean preset. If the PC program still shows the preset though, this is an easy fix. Simple load that preset and save it to the amp. I don't have it with me right now so I can't walk you through it, but maybe later I can take a look. Quote Link to comment Share on other sites More sharing options...
andgo Posted September 10, 2019 Author Share Posted September 10, 2019 You said that I need to make simple load that preset and save it to the amp I did it. Maybe I did it wrong? Quote Link to comment Share on other sites More sharing options...
andgo Posted September 28, 2019 Author Share Posted September 28, 2019 I have decided my problem Previosly I used pc windows 7 (with spider remote) + cable (usb type A - usb micro B) + Spider V20. I have had problems with this set up which I have tall earlier. How I solved problem: iPhone (with Spider Remote for IOS) + cable (Apple USB Camera Connection Kit) + cable (USB type A - USB micro B) + Spider V20. After this setup all settigs оn the switch "Preset" had returned (the same as in the manual) Please, soft developers for line 6 pay attention Quote Link to comment Share on other sites More sharing options...
Montalvo41 Posted February 25, 2021 Share Posted February 25, 2021 I have a couple of questions related to the Line 6 Spider v20 amp. I really enjoy the the setting/preset on the 20V amp called 3A Chunk 1. I recently purchased a line 6 Spider V 60 amp. I can't seem to find this same setting/preset on the V 60 amp. Is called the "Big Bottom?" If so, is there any other things that I need to do to get this sound. Such as: cabinet type or amp settings? The other question. I want to record music using my 20V amp into my apple i phone. Is the usb input called mini USB B Connector? Also, do i need a female side to connect to my phone. Thank you for your time. F.R. "El Capitan" Montalvo Quote Link to comment Share on other sites More sharing options...
