sami568 Posted September 20, 2019 Share Posted September 20, 2019 What is the easiest way to boost signal before entering an amp model? Some of the models (for example the bassman) dont have much gain and give more if you drive them with a hotter signal. I know I can insert an EQ in front of the amp model and just increase the EQ output level without making any EQ adjustments, but is there a way to do this without using up one of my 6 blocks? THanks! Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 20, 2019 Share Posted September 20, 2019 If you have an overdrive/distortion block before the amp model, you could boost the level of that block per snapshot if you want. But there's no way to boost the signal internally before an amp block without having a block of some sort before the amp block. Quote Link to comment Share on other sites More sharing options...
amsdenj Posted September 21, 2019 Share Posted September 21, 2019 Try using Derailed Ingrid. Trainwreck is similar to Bassman but with more gain. Its a great amp for HX Stomp since you can get great distortion tones by just attaching a few parameters to a footswitch (amp drive, bass, presence, cab high/low cut, etc.) without having to use any distortion blocks. Quote Link to comment Share on other sites More sharing options...
