telengard 1 Posted September 20, 2019 I'm playing through a Helix into the Power Cab using the Line 6 link. I also want to record what I'm playing into my recorder. I connect the XLR output into one of the inputs of my recorder and I get extremely low output. The manual states it is line level, but the output I'm seeing is pretty weak. Is there a setting somewhere to control the gain/output level? Quote Share this post Link to post Share on other sites
telengard 1 Posted September 22, 2019 I've tried both an XLR to TS and XLR to TRS cable into my mixer and same results, super low output. Quote Share this post Link to post Share on other sites
Belew01 6 Posted September 23, 2019 Verify that your PC+ xlr output is set to line. It also has the option of mic level which is much lower. Quote Share this post Link to post Share on other sites
telengard 1 Posted September 23, 2019 Hi, thanks for the info. Where exactly can you set that? I don't see it in the Pilot's guide. That guide just says it's a line out. "Connect to an analog mixer's input. This output is Line Level with a maximum of +13dBu." Quote Share this post Link to post Share on other sites
Belew01 6 Posted September 24, 2019 See PC+ manual pages 7, 17, and 19: 12. & 13. XLR Output Jacks - Connect to a mixer's input. The output level is switchable between Line Level (+13dBu) or Mic Level (~0.0dBu) - see "Global Settings" on page 17. Global Settings These global parameters allow you to optimize the Powercab Plus system for your particular needs, whether it be for practice, on stage or in the studio. These settings are persistent (automatically saved) and not part of the preset data. 1. To view Global Settings, press and hold HOME. 2. Turn the SELECT knob to scroll up and down the Global Settings list; press SELECT to toggle between scrolling the list and setting values. Quote Share this post Link to post Share on other sites
rayray6 5 Posted October 3, 2019 On 9/23/2019 at 12:58 AM, Belew01 said: Verify that your PC+ xlr output is set to line. It also has the option of mic level which is much lower. Thanks for the tip. My PowerCab112 Plus "Direct Out Level" was set to MIC, as delivered from the factory. Quote Share this post Link to post Share on other sites
