Sign in to follow this
vcline6
Looper to try different cab settings
Hi all
I'd like to record a loop (bass) and play it back while changing the cab's settings (mic type, distance...) so I created the attached chain in which the looper is the first element.
It seems to me like the sound is different with the looper engaged than if I play the loop with the same settings. Am I doing anything wrong?
Thanks in advance
The looped sound with all loopers is never as high quality as the sound of the guitar without a looper.  I also want to know that answer to that question!  I have not tried the Helix looper yet (and cant now because everyone is sleeping in my house!) but I have tried so many loopers and they all have this issue to some degree.   (I noticed the same problem with the looper in my AxeFXIII).  The best looper I ever used was the Boss RC300, but it still colored the sound.  I currently use a Pigtronix Infinity which is almost as good as the RC300.  I use it in a parallel loop so it does not color my main signal and then use the wet-only signal out to blend with my unaffected signal (how I also used the much larger RC300).  Before blending back, I take the looped signal through a Pendulum 4 band parametric EQ in an effort to get the EQ closer to my main guitar sound - I get it pretty close using the EQ but never perfect. Why cant someone make a looper that does not color your signal?  The fact that the Helix converts your signal to digital is not the issue because  when I record my guitar in my digital DAW on my PC, the sound is perfect and sounds identical to the sound of my guitar - so it IS possible to have a perfect looped tone!   When we play through the Helix, our guitar signal is already converted to digital and it sounds fantastic - so it should be easy for the Helix to just store the numeric representation of our signal and play it back again.   Right???
Two things to check:
- looper playback level. If this is less than 100% it will sound a bit different just due to the volume level change.
- looper record speed and mono/stereo. These settings can also affect the playback sound. For best comparison to guitar input use full speed mono.
On 9/21/2019 at 2:55 PM, sami568 said:
(2^24 bits/sample) x (48,000 samples/sec) / (2^8 bits/byte) x (60 sec/min) / (10^9 bytes/gig)  = 189 GIGS of memory
Thanks for your reply Sami
I think your formula is not correct, instead of 2^24 it should probably be 24 since 24 bits (3 bytes) are sampled 48000 times per second -> ~8MB for 1 minute which makes sense since an audio CD is ~650MB for 44100Hz/16Bit/Stereo. I don't think memory is the issue in this case...
Thanks for your reply silverhead
I did not change any of the default looper settings (screenshot attached).
My config is full speed mono.
Yes!   You are of course correct ....   Thanks for correcting my error...  (I just deleted my flawed calculation)
