AlanRoll Posted January 18, 2014 Share Posted January 18, 2014 I have just bought a stagesourceL2t to pair with my HD500 using L6 link. It sounds fantastic but keeps defaulting to PA mode when I change patches from electric to acoustic sounds. I have updated all firmware - anything I'm missing? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 18, 2014 Share Posted January 18, 2014 The HD500 controls the L2t mode setting when connected via L6 Link, although the setting is not visible in the HD500 device or HD500 Edit. However, when you SAVE and HD500 preset it also saves the current mode setting of the connected Stagesource speaker. What you should do, for each preset, is manually set the L2t mode to your preference and then save the HD500 preset. This will store the setting in the HD500 and recall it each time you recall the preset. Quote Link to comment Share on other sites More sharing options...
AlanRoll Posted January 19, 2014 Author Share Posted January 19, 2014 When I demo-ed it in the store it was with an HD500X and the patches changed automatically - is that normal? it was straight out of the box so presumably the 500X patches carry the data already? Just a thought but would it not be easier if this parameter was visible in HD500 Edit. Off to try this now, love the stagesource sound quality. Quote Link to comment Share on other sites More sharing options...
pugdealer Posted January 21, 2014 Share Posted January 21, 2014 I've actually submited to ideascale the ideia of having the MODE shown and controlled from the POD...it would be much more practical! The 500 and the 500x function in the same way in regards to the stagesource speakers, so you just have to manually select the mode on the speaker and then save it on the POD...you should be running the latest firmware on the pod, which is 2.2 in order to do so! Quote Link to comment Share on other sites More sharing options...
AlanRoll Posted January 21, 2014 Author Share Posted January 21, 2014 Sorted now - yep seems obvious when you know how. Thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
