godfather_77 Posted October 9, 2019 Share Posted October 9, 2019 I'm using the HX stomp Is there a shortcut or suggestions for adjusting the volume level across different presets so you don't get ones that are too low or high? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 9, 2019 Share Posted October 9, 2019 12 minutes ago, godfather_77 said: I'm using the HX stomp Is there a shortcut or suggestions for adjusting the volume level across different presets so you don't get ones that are too low or high? There are no shortcuts, no. Listen and adjust accordingly. Stand by to be told that you need six different varieties of dB meters, a live chicken, and a Ouija board to level patch volumes properly. Pay no attention. The two things you need, you already have: 1) Ears. 2) The channel volume parameter, and/ or the output block volume. 1 2 1 Quote Link to comment Share on other sites More sharing options...
godfather_77 Posted October 9, 2019 Author Share Posted October 9, 2019 thanks! Quote Link to comment Share on other sites More sharing options...
velaramon Posted October 21, 2019 Share Posted October 21, 2019 Following up. Is it better to use the output block volume or a separate gain block? Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted October 21, 2019 Share Posted October 21, 2019 1 hour ago, velaramon said: Following up. Is it better to use the output block volume or a separate gain block? That really depends upon the sound you're trying to achieve. Gain blocks will interact with other blocks within the signal chain to produce unique sounds/distortion depending upon what you have after it. If you like that . . . great . . .if not, don't do it. In regards to the original poster, they were using an HX Stomp which has only 6 blocks. When I was using the Stomp, and because of that unique limit, anytime I could get away with using the output block OR some level option (such as on the amp) I would go that route instead. Quote Link to comment Share on other sites More sharing options...
