billholder Posted October 11, 2019 Share Posted October 11, 2019 Hi just received my Helix haven't even set it up yet, but a dumb newbie question - can it be rigged to receive stereo input (from say, a Roland GR-55) via the fx Return inputs 1 and 2? Or maybe using the guitar and aux input? I've been digging at the manual but not finding anything obvious. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 11, 2019 Share Posted October 11, 2019 If you're only using one path, you can set Path 2's Input to Return 1/2. If you're inserting the GR55 into a path you can set a block to Return 2, pull it down to create a parallel path, then put Return 1 in the upper path. Quote Link to comment Share on other sites More sharing options...
billholder Posted October 11, 2019 Author Share Posted October 11, 2019 1 minute ago, rd2rk said: If you're only using one path, you can set Path 2's Input to Return 1/2. If you're inserting the GR55 into a path you can set a block to Return 2, pull it down to create a parallel path, then put Return 1 in the upper path. Cool thanks. I'll pretend I understand what that means and nod my head and smile and go read the manual more. Thanks. :D Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 11, 2019 Share Posted October 11, 2019 On 10/11/2019 at 11:52 AM, billholder said: Cool thanks. I'll pretend I understand what that means and nod my head and smile and go read the manual more. Thanks. :D Here's a couple of screenshots. Hope it helps. 1 Quote Link to comment Share on other sites More sharing options...
billholder Posted October 11, 2019 Author Share Posted October 11, 2019 Excellent! Thanks again! Just getting started, dipping a toe in, these waters get pretty deep pretty fast! :D Quote Link to comment Share on other sites More sharing options...
