best option for volume level
godfather_77
If you like the way the preset sounds, and all you want to do is change the final output level, use either a Gain Block at the end of the signal chain or the Output Block level.
Anything within the chain, including Channel Level on the Amp (which can affect anything after the amp) can affect everything that follows the block in which it occurs.
