Sign in to follow this
CrazyDave2021
Digital Delay Acting Up
On my Spider IV 150W, I have a small problem. I'll just be playing a song, and the digital Delay knob is all the way down, but it blinks red and cuts off any effects already applied from that knob, even though I'm just using a preset. It happens on any preset. I've factory reset numerous times and nothing. Please help.
Carefully pull up the knob and make certain the retainer nut on that pot is snug.
If that doesn't fix, then it will need servicing by a Line 6 authorized service center.
Knob 'creep' is not unusual with the Spider amps - loud volume can actually make a loose control move enough to trigger a change.  One solution is to put a rubber O-ring around the shaft, then put the knob back on tightly, the o-ring will make it harder to turn.
