geetar_geek79 Posted December 1, 2019 Share Posted December 1, 2019 Is it possible to play through both the AES input and XLR analog input at once when using two sources? For example Helix in AES and modeler 2 in analog ins? Quote Link to comment Share on other sites More sharing options...
uelef Posted December 1, 2019 Share Posted December 1, 2019 The manual says that you can use the AES input for the Helix and Input 2 for PA monitoring … So I guess you can use both together: AES and input 2. But I did not try it … Quote Link to comment Share on other sites More sharing options...
cheekybeermonk Posted October 8, 2020 Share Posted October 8, 2020 As an aside, I had the L6 link cable and midi connected at the same time from my Helix LT to my PC 112 plus ( using midi to control the Powercab volume) when I was changing presets that had specific speaker models selected I had to select the preset twice before the Powercab would change speaker model, disconnected the midi cable and now it works as expected ... Quote Link to comment Share on other sites More sharing options...
