Wet/Dry/Wet Question
monnkey2
I'm thinking of getting a Helix to run in 4CM with my Marhall JVM, and I want to run it in a wet/dry/wet setup. I want to run the dry signal through my 4x12 cab and the stereo wet signal through my studio monitors. Can I send the unbalanced line out of my attenuator back into the Helix, so I can get my whole amp signal (including the power amp section) back into the Helix for the wet signal? Would I send it from the attenuator into the Aux input of the Helix or into one of the loop returns? Would this work?
I don't have an attenuator so I haven't tried this, but if it's a LINE level signal. send it into a RETURN (don't forget the RETURN BLOCK), and in GLOBAL SETTINGS-INS/OUTS set that RETURN to LINE. Should work fine. Expect a small bit of latency for the  A/D conversion, but you probably won't notice, it's tiny.
