pierre_bedos 0 Posted December 13, 2019 Hello everyone, I have a FX100 and I play most of the time with headphones because I live in a flat. The wire of the headphone is sometimes bothering when I play and I have therefore bought a Bluetooth headphone. I have tried to connect the headphones but it is not working. I have tried the following: 1) trying to pair the headphone to the pedalboard directly (did not work) 2) pairing my tablet to my pedalboard as I usually do and then going to the ampli setting ("device selection") and selected my headphones (did not work) I don't know what I am doing wrong and I am wondering if the solution could be to buy a bluetooth transmitter, plug it to the pedaboard via the headphone IN and try to then connect to it with my headphones. Thanks a lot for your help and time. Pierre Quote Share this post Link to post Share on other sites
phil_m 4,517 Posted December 14, 2019 The AMPLIFi doesn’t send audio over Bluetooth, it just receives it. So, yeah, you would need a Bluetooth transmitter to make it work The latency associated with Bluetooth probably would make it unusable, though. Quote Share this post Link to post Share on other sites
fflbrgst 1,852 Posted December 16, 2019 I agree with Phil - Bluetooth latency (delay) would make it very hard to use. I had some wireless (non Bluetooth) headphones that had the same problem, the delay was not as bad as Bluetooth can be, but it was enough to make it a problem. Quote Share this post Link to post Share on other sites
