rekejoso Posted December 29, 2019 Share Posted December 29, 2019 Hi! I have a POD XT live so many years ago, and recently my PC let recognising my POD. I have checked in various pcs and changing the USB cables and ports, and dont run. My question is if there are some way to restore facory settings without connecting the POD to the PC. I want to restore my POD manually. Thanks! Quote Link to comment Share on other sites More sharing options...
boomerz Posted December 31, 2019 Share Posted December 31, 2019 ive also researched it apparently there is no way to reset without conncting to a pc/laptop I just want to do a reset on mine as well so if you come across the andswer please share thanks in advance ive managed to to get it connected to line6 monkey but no option for factory reset on that :( Quote Link to comment Share on other sites More sharing options...
Triryche Posted January 8, 2020 Share Posted January 8, 2020 When you tried different PC's did you install the drivers? Quote Link to comment Share on other sites More sharing options...
boomerz Posted January 20, 2020 Share Posted January 20, 2020 yes everything says installedall green ticks so allok but as I said I just want to reset the pod xt live back to factory settings as the person whom had this before me had all sounds set to heavy meta or grunge and none of the original melodic sounds are there so I simply need a guide step by step of factory reset Quote Link to comment Share on other sites More sharing options...
skydiveboy Posted January 31, 2020 Share Posted January 31, 2020 Dude, read c a r e f u l l y, this can save you weeks of frustrations, this happened to me..... no matter how stupid it sounds.... are you using exactly the original line 6 power source A.C. adapter ??? not a regular-similar 9 V D.C. power source..... read carefully... the power source its the problem it happened to me... you need to be sure using the original A.C.power source (Not a regular D.C.) ...... iiiiiffff you use a regular 9V D.C. the input signal goes to ground and it does not process anything..... I was using a 9V D.C. and no signal and I spent 1 week doing all kind of updates and contacting techinal support for nothing... after I found my original power source and connected ...voila it works like a charm...I read many guys on internet having same problem and technical support not giving them any answer telling them "send them to us so we can check it up"..... and charge you for that..... use a 9V Altern Current.... not D.C....... do it now Quote Link to comment Share on other sites More sharing options...
boomerz Posted February 1, 2020 Share Posted February 1, 2020 yup all power packs and cables fine and the correct ones (original powerpack from new) Quote Link to comment Share on other sites More sharing options...
daveny5 Posted February 18, 2020 Share Posted February 18, 2020 What version of Windows are you using? You may need to download the correct driver for that version. Quote Link to comment Share on other sites More sharing options...
