Sign in to follow this
GUITAR65a
expression pedal volume adjustment
Good morning
I tried the procedure as in the manual but at the end the pedal goes from zero volume to maximum volume, without intermediate adjustments.
 I probably didn't apply the procedure well as it was explained in a rough way.
Can someone help me? Maybe if you repeat the procedure in a precise and accurate way
Thanks
In the Volume Pedal setting the min & max position did you adjust that and save tone.
That works for me
Good Luck
I think Harold is misunderstanding you.
I too have the same problem using the expression pedal for Pitch Glide.
I want it to hit all the notes on the way down but it seems to go from minimum to maximum without the values between.
Is there a calibration setting anywhere? I can't find one
