patriot2006 Posted January 17, 2020 Share Posted January 17, 2020 Good morning folks, Just received my HX Stomp yesterday. Had a minor issue when trying to create a snapshot. The left controller has a tube screamer and a delay that is turned off. The middle pedal has both items turned on for soloing. After creating the snapshot it worked fine until I moved on to something else. Everytime I came back to the snapshot the delay would be turned off. I tried to reset it multiple times with the same results. Am I missing something, is this a known issue? I will check back when I get back from the chiropractor. Old bodies need a little help! Thanks for any assistance you can provide, Regards, Rich Quote Link to comment Share on other sites More sharing options...
brue58ski Posted January 17, 2020 Share Posted January 17, 2020 Hard to assess from here. You're not completely specific about your creation procedure. So the first thing, which you probably already did, did you save the patch after you created/changed the snapshot? I know, probably an obvious thing to you but I'm not quite sure what else it could be. Quote Link to comment Share on other sites More sharing options...
patriot2006 Posted January 17, 2020 Author Share Posted January 17, 2020 Are you saying I have to save the new snapshot before I assign it to a controller? I would think if I change the patch it would affect the original or am I wrong? Quote Link to comment Share on other sites More sharing options...
