felipemartin Posted January 17, 2020 Share Posted January 17, 2020 Hello, I have a Roland JC-120 and a JC-40. ¿How can I use the CLEAN pre amp of this amps on a clean setting, BUT the HX Stomp DIRTY Preamps on the JCs when I need some dirt? Also, Is there a 5 cable method? My idea is to have a Stereo setup with only ONE of the amps. Best regards and thank you all. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 17, 2020 Share Posted January 17, 2020 2 hours ago, felipemartin said: Hello, I have a Roland JC-120 and a JC-40. ¿How can I use the CLEAN pre amp of this amps on a clean setting, BUT the HX Stomp DIRTY Preamps on the JCs when I need some dirt? 4cm. Put the FX Loop and the HXS preamp on the same footswitch, saved with one ON one OFF, so that hitting the switch toggles them. 2 hours ago, felipemartin said: Also, Is there a 5 cable method? My idea is to have a Stereo setup with only ONE of the amps. You need Helix Floor or Helix Rack. With HXS you can have 4cm on two of your amps, OR Stereo on one, but then you're out of physical loops, and you've already used 2 of your 6 available blocks. Quote Link to comment Share on other sites More sharing options...
felipemartin Posted January 19, 2020 Author Share Posted January 19, 2020 Thanks a lot! Quote Link to comment Share on other sites More sharing options...
