Best Practices Setup - Hd Pro X To L3t Via L6 Cable
USMC7312
not sure what you are looking for... it's pretty straight forward. L3 will configure itself based on the connection so all you have to do is build your patches.  Unlike the DT, the L3 usually sounds best with the full amp models.  PM me if you want.
PS - 6032, F,R,T, - 152,352,452
So just to confirm.  I connect the L6 cable and the only thing I need to do is change the input settings on each patch along with making sure the pre-amp is enabled as well.  I don't need to worry about the speaker settings on the back of the L3T at all?
