unperfectcircle Posted February 25, 2020 Share Posted February 25, 2020 Hi, could you please tell me if the HX Effects Pedal/Ext Amp outputs can control the Suhr FX Link feature on the Eclipse pedal (with an adapter cable of course)? The FX link is a latching system. The switch to TRS connections are described in the attached drawing. Thanks a lot Eclipse_TRS_Jack.pdf Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 25, 2020 Share Posted February 25, 2020 Should work, BUT....I watched the Pete Thorn demo on YT, and it looks like the HXFX setting "NONE" would be BYPASS, but I would avoid trying "1 and 2", as it doesn't look like there's a "stacked" option. You might contact support to see what would happen if you did that, because accidents happen, and you wouldn't want to let the magic smoke escape! Quote Link to comment Share on other sites More sharing options...
