Turkeyroller Posted February 28, 2020 Share Posted February 28, 2020 Hello, I am thinking about picking up a HX Stomp to hopefully replace my amp. The only issue is that I run a preamp pedal that uses a 4 cable method to keep my external effects in the fx loop of my amp. The Preamp pedal runs a line into the front of the amp so I can still use my amps preamp, and also runs a line into the fx loop for when I want to use the Preamp pedal. Basically when the preamp pedal is off it acts as if it isn't in the chain and my amp works as normal, but when I turn on my preamp pedal it by passes my amps preamp. To illustrate my normal pedal board is routed this way: First Part: Guitar >>> Front Pedals(Comp, Overdrive, etc..) >>> Preamp (FIrst Input) >>> Amps Normal Input Second Part: Amp FX Send >>> Preamp (Second Input) >>> (Preamp Pedal FX Send) >>> Delay >>> Reverb >>> Amp FX Return I would love to be able to insert my pedalboard as a block in order to take advantage of placing effects in front of my pedals. As far as I can tell, the only way to do this is to chain your guitar into the HX stomp then from your HX Stomps FX Send into your pedal board and back to the FX Return of the Stomp. So my question is, can anyone see a way to make this work either within the HX Stomp itself or even with some external hardware? Thanks! Quote Link to comment Share on other sites More sharing options...
