b3co0l Posted March 5, 2020 Share Posted March 5, 2020 My updater can't see the HELIX device. I have Win 10 PC. When I insert usb cable,windows gives a sound and when I check task menager I see the device with yellow sign with ! so is a problem. I suppose it is why my line 6 updater (1.18) can't see HELIX. Maybe somebody can help me? THX. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted March 5, 2020 Share Posted March 5, 2020 41 minutes ago, b3co0l said: My updater can't see the HELIX device. I have Win 10 PC. When I insert usb cable,windows gives a sound and when I check task menager I see the device with yellow sign with ! so is a problem. I suppose it is why my line 6 updater (1.18) can't see HELIX. Maybe somebody can help me? THX. Make sure that you close HX Edit first. You can't have both applications running at the same time. Quote Link to comment Share on other sites More sharing options...
Peter Posted March 5, 2020 Share Posted March 5, 2020 "Make sure that you close HX Edit first. You can't have both applications running at the same time."(VirtualGuitars) If that does not work: Disconnect the Helix. Reinstall HX Edit 2.82 (and all included drivers) and try again. ... or try a different USB port Quote Link to comment Share on other sites More sharing options...
b3co0l Posted March 6, 2020 Author Share Posted March 6, 2020 Problem solved. I simply installed HX Edit it contain drivers which I use for unknown device in task manager, and Helix show up. THX very much friend. Quote Link to comment Share on other sites More sharing options...
nvrick184 Posted August 1, 2021 Share Posted August 1, 2021 THANK YOU b3co0l THIS WOrked after hours of searching Quote Link to comment Share on other sites More sharing options...
