GJ77 Posted March 11, 2020 Share Posted March 11, 2020 Hi folks. I have been using the Helix stomp for a short while and will mainly use it for live. I also recently got the Neural DSP plugin and want to continue using the stomp as my audio interface. So, while I can hear that i am using the Neural, I can also still hear the Stomp. I've tried creating a blank patch, I've tried different input and output options but I can still hear the Stomp come through. In the blank patch it is just a dry I'm getting which would normally be ideal, but to hear simultaneously with the distortion isn't ideal! Just can't get rid of it. I've also tried direct monitoring from my DAW (Logic) but that changes nothing as far as the helix is concerned. Does this mean that there is no bypass on this unit? Quote Link to comment Share on other sites More sharing options...
rayray6 Posted June 8, 2020 Share Posted June 8, 2020 If you are using a DAW, set the track input (for the track on which you have the Neural DSP plugin loaded) to Input 5. Then, to get rid of the dry signal, on the HX Stomp preset signal chain, turn the Output block's level all the way down to -120.0dB. If you are using the Neural DSP plugin in standalone mode, it may not work. I cannot get it to recognize any other Stomp input than 1 & 2 and even then, there is no signal recognized by the plugin. Quote Link to comment Share on other sites More sharing options...
Dehz Posted August 11, 2020 Share Posted August 11, 2020 On 6/8/2020 at 2:18 PM, rayray6 said: If you are using a DAW, set the track input (for the track on which you have the Neural DSP plugin loaded) to Input 5. Then, to get rid of the dry signal, on the HX Stomp preset signal chain, turn the Output block's level all the way down to -120.0dB. If you are using the Neural DSP plugin in standalone mode, it may not work. I cannot get it to recognize any other Stomp input than 1 & 2 and even then, there is no signal recognized by the plugin. Hi, I'm also trying to accomplish this with no luck. In Logic Pro, I set it to Input 5, and on the patch on my Stomp I turned the output block's level to -120. I do not get any sound whatsoever now, any thoughts? I'd really like to just put my Scarlett 2i4 away for good. Quote Link to comment Share on other sites More sharing options...
freezerlord Posted December 1, 2020 Share Posted December 1, 2020 Hey there! Did you guys find a solution in the meanwhile? I just got my brand new stomp and am still wondering if the idea to use the HX as an interface for other plugins (like e.g. neural DSP) is actually a bad one. I'm currently comparing the sound I get when playing through a focusrite 8i6 (which I've got from a friend for testing purposes) against the one I get through the stomp. Sadly, it doesn't seem to be on the same level atm :( any impressions? Comments? Experiences? Help? :) Quote Link to comment Share on other sites More sharing options...
