Refurbishing Relay G10 Receivers
jon_bondy
I purchased a used Relay G10 Receiver, and the USB connector separated from the PCB fairly quickly.  I re-wired it so that it can get power from a USB port (which I have on the power strip I use in my pedal board).  If anyone has a Receiver that needs this repair, please get in touch.  I can either walk you through it, or do it for you.  Note that, while this solves the problem of how to power the Receiver, it does not fix the USB port, so you will not be able to install firmware updates any better than before the repair.
I've seen that before.  It will work if you get to it before the USB connector separates from the printed circuit board.  Once the connector has separated, you will need another approach.  I connect a USB cable directly to the PCB to supply power, but not data.
