shanto123456 Posted April 17, 2020 Share Posted April 17, 2020 My pod hd 500x auto rebooting. I tried with new adapter and also I couldn’t get any technical support because they do not know to to solve It. And the most sad part is i am 60881981626__E07DD63B-A675-48A8-AC2B-D49B350A4E25.MOV waiting for any solution for more than one year, re booting problem was started on end of 2018 :). Quote Link to comment Share on other sites More sharing options...
hurghanico Posted April 18, 2020 Share Posted April 18, 2020 If you have already tried another power supply with exactly the same specs as the original, the last possibility (if you have not already done so) is to try a firmware update in safe mode. Here is the procedure: Power Up the device while pressing the Nav Pad Down button. On the device screen you should see UPDATE FLASH. Connect the device to the computer through USB. If the device is recognized by the computer (if not there is nothing else to do than have it repaired) you can use the Monkey program to re-install the latest firmware,. When done, do a Global Reset and finally a Pedal Calibration _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
shanto123456 Posted April 19, 2020 Author Share Posted April 19, 2020 Tried all the things. And usb device was not recognised. I know i have to repair it but in my country no-one knows how to repair it. So anyone can help me online what to do or which part need to be changed then i can tell them :( Quote Link to comment Share on other sites More sharing options...
hurghanico Posted April 19, 2020 Share Posted April 19, 2020 Hoping that the USB controller chip has not been damaged too, to find a new USB connector replacement part near your country look for 649-61729-1011BLF by using google-- Here is a video clip with a few DIY suggestions If you need also to replace the USB controller chip I believe you should look for CY7C68013A-56PVXC _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 19, 2020 Share Posted April 19, 2020 Well.... The device not being recognized by the pc isn't necessarily related to this problem. And that, unfortunately, means you may not be able to fix this issue yourself. Quote Link to comment Share on other sites More sharing options...
