cho7 Posted April 22, 2020 Share Posted April 22, 2020 Hi there, I'm trying to record my guitar using my macbook, audacity, and of course my HX Stomp. I read that no driver is required on Mac if I'm using 48Khz sample rate, so I simply plugged the stomp into the macbook and, indeed, it is detected by the system. But so far, I have not been able to get any sound from the usb audio interface. I set the HX stomp as recording device from the Audio MIDI Setup application, but I can't set master volume nor channels volume Yet, I tried to selected the proper interface and channel (1) in Audacity and expected a miracle : But of course I have a flat line. So is there something I missed (the audio output knob on the stomp is set at max) Many thanks ! Quote Link to comment Share on other sites More sharing options...
cho7 Posted April 23, 2020 Author Share Posted April 23, 2020 OK I've just tested with another software (garage band) and it works as expected. The problem is from Audacity then, and we can consider it as solved. Thanks anyway ! ! Quote Link to comment Share on other sites More sharing options...
pedcot Posted February 12, 2021 Share Posted February 12, 2021 I have the same problem, did you fixed it? Thanks, Pedro Quote Link to comment Share on other sites More sharing options...
