HX Stomp + Mac + Logic Pro X latency issue
jucbes
Hello,
Disclaimer: I'm a recent owner, and a total newbie in modellers, USB recording, DAW, etc.
So, I have a Mac Book Pro 2015 running Mojave and installed Logic Pro X (3 month trial, nice), connected the Stomp and got some recording done pretty quickly. Pretty cool!
I use the Stomp as input (duh), I set the output to system setting, then I have headphones connected to the Mac to listen to everything (usually I just do silent recording in the evening).
Now the issue. Frequently, while I'm playing over a recording, layering stuff, very suddenly the latency jumps a lot. And I'm talking 1, 2 or even 3 secs latency. The latency applies only to the input guitar signal, whatever is already recorded is fine. I need to restart Logic to fix it. Until next time.
Any hints to avoid this issue?
Also, about Helix Mac driver, could it help with this? Should I install it? Or that is just for macOS/OSX versions older than Mojave?
Thanks in advance!
Yep, everything said above. When the Stomp is connected to your Mac, it *becomes* your sound card, and if you want all the benefits of using it, you should not be listening through any of your built-in ports on your Mac. Also, I don't know how this is done in Logic, but in general with DAWs there is a way to turn on/off software monitoring for an audio input. When using your Stomp, you also want that to be OFF, or else you'll hear the direct hardware-monitored sound doubled with the software-monitored sound, which will usually have a small delay and make things sound odd. When configured correctly, you'll hear your guitar signal with no perceivable latency, and after you record something, it should all be aligned in sync with everything else in Logic.
Well, you are all absolutely right indeed!
I switched the output to the Stomp, and connected my headphones to it instead. I've been recording for 2 hours now without a single hiccup.
Thank you very much!
It happened exactly like you said. There's an "input monitoring" toggle on each track, was a quick fix. Thanks for the tip.
