myl6username Posted May 10, 2020 Share Posted May 10, 2020 I bought a new asus laptop and when i use my good ol' POD HD500X --> USB --> Audacity 2.3.3, i have a critical error every time. When i record a new track on a project with any other tracks, as soon as the recording is done it tells me i have dropouts and the tone of the track is a full step or more lower (if not totally garbled and crazy). My new band can't record and i promised them this would be cheap and super easy and i'm desperate... any help is immensely appreciated! So far tried updating windows and turning off wifi and turning on airplane mode (read this in another thread, but didn't help). Tried plugging in different USB port, no help either. Below is the step-by-step of things that work until the final result that doesn't work. So many variations work fine, it's only recording over a project with a new track via line 6 that doesn't work, and only when Line6 is both input and output. Setup: *Line6 pod hd 500x *Windows 10 Home, ver 1903 *Audacity 2.3.3 *Asus laptop Intel Core i7-8565U CPU @ 1.8GHz 16GB RAM 64bit OS, x64-based processor 1) *NO line 6 plugged in, record via realtek audio laptop speaker - ok Input Source : Realtek audio Output Source: Realtek audio 2) *NO line 6 plugged in, playback + overdub new track via speaker - ok Input Source : Realtek audio Output Source: Realtek audio 3) *YES line 6 plugged in, playback + overdub new track via speaker - ok Input Source : Realtek audio Output Source: Realtek audio 4) *YES line 6 plugged in, record via realtek audio laptop speaker, playback via line6 - ok Input Source : Realtek audio Output Source: Line6 5) *YES line 6 plugged in, record **FIRST** track via line6 (so nothing playing back while recording) - ok Input Source : Line6 Output Source: Line6 6) *YES line 6 plugged in, playback + overdub a 2nd or more track via line6, but output is laptop speaker - ok Input Source : Line6 Output Source: Realtek audio --> i can even play this back via output source Line6 after its recorded and it's still fine. 7) *YES line 6 plugged in, playback via Line6 + overdub a 2nd or more track via laptop speaker - ok Input Source : Realtek audio Output Source: Line6 8) ERROR TIME!!!!! *YES line 6 plugged in, playback + overdub a 2nd or more track via line6 - dropouts detected, full step down in tone of the second track, possibly sync errors too-->CRITICAL ERROR Input Source : Line6 Output Source: Line6 So ONLY when i have Line6 as the input AND output source (and output seems to be the worst offender), and also only when there is already at least 1 pre-existing track, I cannot record without severe errors. Please help :-( Many thanks in advance Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 11, 2020 Share Posted May 11, 2020 You don’t mention drivers at all. The most common issue with Audacity is its default driver called ASIO4ALL. When using Line 6 equipment you need to use the Line 6 ASIO driver. Quote Link to comment Share on other sites More sharing options...
myl6username Posted May 11, 2020 Author Share Posted May 11, 2020 39 minutes ago, silverhead said: You don’t mention drivers at all. The most common issue with Audacity is its default driver called ASIO4ALL. When using Line 6 equipment you need to use the Line 6 ASIO driver. thanks for the advice - where would i look to see what driver is being used and change it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 11, 2020 Share Posted May 11, 2020 15 minutes ago, myl6username said: thanks for the advice - where would i look to see what driver is being used and change it? Somewhere in the Audio Preferences / Settings. I’m not familiar with the details of how to configure things in Audacity. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 11, 2020 Share Posted May 11, 2020 .... or you could try using a different audio recording program (DAW). I use both Reaper (free trial period then very affordable) and Cakewalk by Bandlab (free). Quote Link to comment Share on other sites More sharing options...
hurghanico Posted May 11, 2020 Share Posted May 11, 2020 Tips: - avoid connecting the POD to USB 3 ports, use USB 2 only ports - avoid installing and using the asio4all driver (tipically needed/used by the Audacity program) - instead of using Audacity use a decent pro level DAW program like Reaper (already suggested above by silverhead) and make always use of the ASIO dedicated driver provided with the POD _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
myl6username Posted May 24, 2020 Author Share Posted May 24, 2020 for posterity, this issue was FIXED by going to windows sound control panel and ensuring that the rates on both recording tab and playback tab of the Line6 device were set to the same sample rate (44.1khz and 16bit CD quality). they originally were not. Quote Link to comment Share on other sites More sharing options...
