No simultaneous Digital Signal when using S/PDF and L6 Link
k21267
Not sure if this is meant to work this way or if it's a bug, but when I use a SPIDF out to my DAW and have my Power cab hooked up to L6 Link the S/PDF signal is terminated. No output what so ever. Can any one confirm if this is indeed how it is supposed to work or if there's a setting I'm missingĀ Seems a little strange to label an output as being multiple outputs but then it kills the signal on one of the outputs. Thanks for any help.
Not a bug, that's the way it works, either/or.
I use the PC XLR out to record, but you may prefer to take a split before the digital output block and assign it to the Helix XLR out to use IRs in your DAW.
FWIW - I've recorded XLR and SPDIF side by side, and if there's any difference it's beyond my ears to detect.
