Elephantstomp Posted June 1, 2020 Share Posted June 1, 2020 Hello guys, I was given so many usefull things here that I like to give something back. For better handling in the heat of battle I wanted to have the right/left switchbutton of my HX-Stomp a bit higher to avoid switching the middle one by accident. I found theese stainless steel curtain rod endcaps: https://www.amazon.de/Endkappe-leicht-gewölbt-10mm-Kleben/dp/B01MDQYGG4/ref=olp_product_details?ie=UTF8&me= They also are available with a flat top: https://www.amazon.de/Endkappe-flach-10mm-Stab-Kleben/dp/B01MG5256O/ref=olp_product_details?ie=UTF8&me= Have a look at the attached pictures! Inner diameter: a bit wider than 10mm. Inner height: 10mm Height of four washers: 4mm Remaining height inside (corresponds line six switchbutton-head height): 6mm Building instructions: Inside theese caps I superglued four washers (all at once an quickliy to get a defined height) Let dry! To get the inner diameter of the cap a bit narrower put some superglue on the inner surface. Let dry! Put the caps on the switches. They fit so tight that you shouldn´t get them off unintentionally. Possibly scratch some glue off to make it fit. If needed you can remove the caps without a trace. This works fine for me and looks great and decent. For the big Brothers of HX-Stomp this could be a cheap second-switch-row solution. Cheers! Quote Link to comment Share on other sites More sharing options...
Lone_Poor_Boy Posted June 1, 2020 Share Posted June 1, 2020 Clever! Quote Link to comment Share on other sites More sharing options...
