nbaird Posted June 3, 2020 Share Posted June 3, 2020 Gentlemen, I was getting distorted sound on my GX, UX2, and UX8 that so many others have described in this forum using Win 10 and a Cherry Trail tablet. It would seem to play at the wrong sample rate and sounded like some bad 8-bit Atari video game noise. This may apply to those with a Surface tablet too. In my case the problem was with the Microsoft Driver for the "Intel(R) USB 3.0 eXtensible Host Controller". Unfortunately Intel discontinued drivers and let Microsoft take over since Win 8. I downloaded the Intel driver 5.0.4.43_v2 for Windows 7, disabled driver signing and edited the .inf to make it work with Win10. After installing the old Intel drivers my Line 6 devices are working properly even through external USB hubs. 2 Quote Link to comment Share on other sites More sharing options...
Dune_uk Posted June 9, 2020 Share Posted June 9, 2020 I’m having a similar problem, can you share the driver? Quote Link to comment Share on other sites More sharing options...
nbaird Posted June 11, 2020 Author Share Posted June 11, 2020 On 6/9/2020 at 5:02 AM, Dune_uk said: I’m having a similar problem, can you share the driver? Before attempting this procedure make sure that you have this same controller on your system. Open Device Manager and expand "Sound, video and game controllers" Highlight the Line 6 device At the top of Device Manager in the "View" menu select "Devices by connection" This will show you a tree where your USB device is connected so you can find your USB Controller. For me the tree was: ACPI x64-based PC Microsoft ACPI-Compliant System PCI Express Root Complex Intel(R) USB 3.0 eXtensible Host Controller The driver can be found at https://downloadcenter.intel.com/download/22824/Intel-USB-3-0-eXtensible-Host-Controller-Driver-for-Intel-8-9-100-Series-and-Intel-C220-C610-Chipset-Family After extracting you will want to edit iusb3hub.inf and iusb3xhc.inf (located in \Drivers\Win7\x64 if you're on 64-bit) as follows: Replace this text [Manufacturer] Intel(R) Corporation = Intel, NTAMD64.6.1, NTAMD64.6.2 [Intel.NTAMD64.6.2] With this [Manufacturer] Intel(R) Corporation = Intel, NTAMD64.6.1 Then restart with the Disable Driver Signature Enforcement option (hold shift when selecting restart/Troubleshoot/Advanced Options/Startup Settings/Restart/Option 7) Manually install the driver in device manager (right click Intel(R) USB 3.0 eXtensible Host Controller/Update driver/Browse my computer for driver software/Let me pick from a list of available drivers on my computer/Have Disk...) Let us know how that goes or post your USB Controller if it's different. 1 1 Quote Link to comment Share on other sites More sharing options...
Dune_uk Posted June 13, 2020 Share Posted June 13, 2020 Thank you Quote Link to comment Share on other sites More sharing options...
borlock Posted July 9, 2020 Share Posted July 9, 2020 This solution with a different set of drivers worked for me. My UX2 is finally working with Windows 10, and my DAW has never worked so well! Thank you nbaird for helping us with this! Quote Link to comment Share on other sites More sharing options...
nbaird Posted July 9, 2020 Author Share Posted July 9, 2020 Great to hear you got it working borlock! I'm attaching the 3.1 driver here for those who have this USB controller. Intel(R) USB 3.1 eXtensible Host Controller - 1.10 (Microsoft) PCI\VEN_8086&DEV_A36D A36D USB WIN7 BETA2.3 UNSIGN.7z 1 Quote Link to comment Share on other sites More sharing options...
nbaird Posted January 20, 2022 Author Share Posted January 20, 2022 x64.7z This is working with Windows 11 too. 1 Quote Link to comment Share on other sites More sharing options...
borlock Posted January 20, 2022 Share Posted January 20, 2022 That's really good news! I was wondering if it would. Quote Link to comment Share on other sites More sharing options...
ForrestAnthony Posted January 13, 2023 Share Posted January 13, 2023 So I'm dealing with this issue right now. I just upgraded to Windows 11 5 days ago and before that, everything worked fine on my end. Now, audacity records slowly (i.e 1 second in audacity takes 4-5 seconds in real life), and the audio comes out extremely distorted, and as you described, like Atari levels of pixellation, as well as high pitched. I won't deny I'm not a computer whiz, but I've tried taking this "x64.7z" you posted here on Jan 19, 2022, and then tried following your steps. All seemed fine until: Quote Manually install the driver in device manager (right click Intel(R) USB 3.0 eXtensible Host Controller/Update driver/Browse my computer for driver software/Let me pick from a list of available drivers on my computer/Have Disk...) this part. When I chose "Have Disk", it only gave me the option to select one single file within the x64 folder you provided. Upon choosing one, it then warned me that this file may make my entire computer malfunction, which is the last thing I need right now. Can you possible add any more clarification to help out? My work-from-home voice studio is banking on this and until I get this fixed, I am screwed. Any help is immensely appreciated. Quote Link to comment Share on other sites More sharing options...
borlock Posted May 13, 2023 Share Posted May 13, 2023 Did you disable driver signing? Quote Link to comment Share on other sites More sharing options...
paashaas Posted December 3, 2023 Share Posted December 3, 2023 Hello, Thanks for the info, that sounds exactly like the problem I am having now. I recently bought a whole new desktop computer and installed windows 11. I installed the latest line 6 driver and monkey but the sound is very distorted. Played a bit with the sample rate but still horrible. Now if I look in device manager I see I have the: Intel USB 3.20 eXtensible Host Controller - 1.20 (Microsoft) driver installed. (from 18-10-2023). Do you perhaps know where I can find the one for this particularly driver? Also I am wondering if this may harm other USB related devices, so perhaps I will just switch to a Windows 11 appropriate device, but I always loved my Toneport UX2 so I would rather use that haha Anyway thanks in advance and hopefully they can perhaps fix this with a new driver! Quote Link to comment Share on other sites More sharing options...
vladone Posted February 27, 2024 Share Posted February 27, 2024 I also have this issue, both on w11 and w10 after I changed my motherboard to MSIZ790 Gaming Plus WiFi. I will return the mobo and try another model if nobody have an answert to this anoying issue. (my son on a MSI PRO B760M-P DDR4 does not have this issue, also, a Scarlet 6i6 is working ok). Quote Link to comment Share on other sites More sharing options...
